vagcom installation
  • andyg plym
    • Nov 2006
    • 4646
    so had a good stab at this this morning and had the same issues where the program would stall and shut down, after some investigation i ran it as an administrator and boom! it works
    so here are the codes i pulled:
    So had some issues recently the main being boost cut/ecu reset.I can sit at idle then rev to say 7k and the rev counter needle pings back to 0rpm also happens in WOT in 1st gear.Then presumed the knock sensors were playing up as it would only boost to 0.5bar, turn the engine off and restart and yes you've guessed it- it boosts as it should.
    I understand th knock sensor fault code, that wasn't a surprise.....but what exactly is 0532?
    I know its some sort of grounding issue, can anyone narrow down?
    • rj scotty
      • May 2006
      • 2195
      Do you use dropbox at all?
      BUT I DON'T WANT A NEW CAR!
      1995 S2 Avant, Volcano Black
