Alternator pulley wheel
  • Rikki Kitto
    • Feb 2010
    • 6276
    Is the diameter of the alternator pulley wheel important?
    Just asking because after getting mine refurbed the shop said it had the wrong pulley wheel fitted. They fitted the supposedly correct one which is smaller diameter than the one that's always been on it.
    It's also wider but don't think this will be an issue as I'm running an S4 one as a spare with no problems and this has a wider wheel, the belt sits nicely in the groves and doesn't seem to move about
  • Kieron20V
    • Mar 2008
    • 1505
    A smaller one would make it spin faster, is it on a diesel?
    Sent from my HTC One X+ using Tapatalk
    1994 URS4 Avant RS2+
    • John.
      • 2615
      Smaller pulley's going to be spinning faster at any rpm compared to larger pulley.
      This would have a benefit at idle speed me thinks?
      • Rikki Kitto
        • Feb 2010
        • 6276
        That's what I was thinking, as long as to much rpm wouldn't cause a problem with load
        • Rikki Kitto
          • Feb 2010
          • 6276
          S2 Coupe'
          • John.
            • 2615
            Don't think load will be an issue but the bearings will be worked harder?
            • Rikki Kitto
              • Feb 2010
              • 6276
              Good point have to keep an ear to that one, don't do high miles in her anyway so sure it will be fine
