hi all, anybody got any tips on how to do this please pic too lol
hardwiring fuel pump
Are you meaning how to take a direct feed from the battery to bypass the thin original fuel pump wiring to stop volt drop?
If so, you need to use the existing wires to fire a relay and then run a cable from positive via a 30A fuse straight to the pump then run a negative feed via the relay to the pump. Make sure all connections are crimped or soldered properly and make sure the fuse holder is up to the task. I dont have many pictures that are of use to you from mine.
I found this online, it is pretty much right apart from dont need to slice into the original feed, you just take it off the original pump.
yep mate that's what I need cheersAre you meaning how to take a direct feed from the battery to bypass the thin original fuel pump wiring to stop volt drop?
Two options to relay your UrS fuel pump to the battery
Two options:
1. You can use myfuel pump relay DIY as a guide:http://forums.quattroworld.com/s4s6/msgs/24327.phtml, adapting it to the B3/B4 as needed
OR
2. just purchase and install 034's kit:
https://store.034motorsport.com/c4-f...relay-kit.html
