Cruise control vacuum pump
  • carboRS2
    • Apr 2011
    • 105
    • Country: Spain
    Hi everyone,
    I'm in the process of installing cruise control and it's being much more difficult than reading your posts suggest.
    I acquired a complete set removed from an Audi A8.
    After routing vacuum tube and wires connected everything but didn't work.
    Found a thread explaining how to check every part.
    First thing to check was vacuum pump and first broken part. So I ordered another one in eBay.
    The new one works. Makes a noise when I give power but it can't pull the throttle. I have checked the lung and it's ok.
    Is this normal or should the pump be able to pull the throttle?
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    You need to give two positives(+) to get the pump to vacuum.
    Once you have the pump to make that "noise" give a + also on the third connection and it should start to suck the membrane.
    Stefano
    http://www.audisportclub.com/
    • A80Avant
      • 10873
      • Country: Greece
      So 3 positives will make it work? I need to check that myself. I have replaced 3 pumps so far.
      Mine kicks in if I keep my switch pressed but doesn't keep it on. The switch is new also
      • carboRS2
        • Apr 2011
        • 105
        • Country: Spain
        Thanks for the quick reply Stefano.
        A80Avant what I understand is 2+ and one ground.
        Will try it tomorrow and post the result.
        • A80Avant
          • 10873
          • Country: Greece
          Can you also post an image showing which one is the ground which the positives?
          • veneto rs2
            • Jun 2006
            • 1022
            • Country: Veneto
            Yes Vasilis I found out that by mistake in all honesty.... Three spades one needs ground of course and two positives.
            It felt to me like the second positive shuts a no return valve on the pump easy to check with a test bulb.
            The ground should (remark on should) be a brown or a brown striped wire
            • carboRS2
              • Apr 2011
              • 105
              • Country: Spain
              Yes!!
              • carboRS2
                • Apr 2011
                • 105
                • Country: Spain
                It worked as Stefano said.
                Looking front to the pump you must wire + in top and right blade and ground in left.
                It completely pulled the throttle this way.
                As soon as I disconnect one of the wires it releases but I guess that's normal.
                • carboRS2
                  • Apr 2011
                  • 105
                  • Country: Spain
                  I've been fighting all day with cruise control and I'm almost there.
                  CC is now working properly but have an issue with headlights.
                  I can do flash but high beam is not working.
                  Has someone had the same problem?
                  I suspect is some pin in the loom that has to be changed...
                  • Val
                    • Apr 2008
                    • 630
                    • Country: Latvia
                    You have to open up beam switch and check and clean contacts
                    5vtq gte
                    • carboRS2
                      • Apr 2011
                      • 105
                      • Country: Spain
                      Thanks for the answer Val. But I already tried it with no luck.
                      Maybe I did something wrong. I've read that the contacts shoud be sanded and I just used contact cleaner but not sanded.
                      • Val
                        • Apr 2008
                        • 630
                        • Country: Latvia
                        Did you previously have headlight switch w/o cruise and it worked?
                        You could move cruise lever alltogether from not working high beam switch to the other.
                        5vtq gte
                        • carboRS2
                          • Apr 2011
                          • 105
                          • Country: Spain
                          Yes. I have the old one and it worked properly.
                          Will try to do what you propose. Thanks for the advice
                          • carboRS2
                            • Apr 2011
                            • 105
                            • Country: Spain
                            Ok. This last issue has also been solved.
                            I dismantled the stalk and found a metal piece bended. I put it back in the right place and now have high beam light again.
                            Finally have fully working tempomat!
                            Thanks for your help
