drivers window not working
  • johnsmart
    • Jan 2011
    • 19
    hi guys,my drivers window is not working,when i press the switch on the arm rest i can hear a a noise like a relay clicking under the dash, what do i need to check to find the problem.any help will be appreciated regards john
  • geryS2
    • May 2006
    • 814
    • Home: Belgium Current: Portugal
    cable jam inside the door, demount panel, check cable or motor, lubricate cable,
    if complete jammed, w ll need to change the mechanism...
    good work...
    S2 's and oldtimers
    • geryS2
      • May 2006
      • 814
      oops ,did nt read you post fully, seems like an electric problem then, not the usual cable jammed, u ll need more support than a amateur mech ! lol
      S2 's and oldtimers
