Dash bulb red cap
  • montyrs2
    • May 2008
    • 522
    Dash bulb red cap
    afternoon all.
    Anyone know if you can get the little red cap for a dash bulb? Non of mine have one and the dash doesn't quite look right at night because of it.
    Only other solution I thought of was to buy some red light tint spray, anyone else done anything?
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    You can get bag of them for cheap on ebay by searching "5mm bulb cap red".
      Originally posted by montyrs2
      None of mine have one and the dash doesn't quite look right at night because of it.
      You're right. None of mine have them either. In fact no factory S2, RS2, UrS4 or UrS6 came with red instrument cluster bulb covers. This is because they aren't needed. The S2, RS2, UrS4 and UrS6 instrument faces ("clock" faces) are multi-layer and one of the layers is a dark red. This looks black when not illuminated from behind and red when illuminated.
      But if you really think you need them for the look you want, Google "red bulb covers" and you will find several sources.
      Click HERE
      • montyrs2
        • May 2008
        • 522
        Click HERE
        I find that the centers of the gauge, around the needle spindle is very white, while the rest of it is red. The caps are cheap enough so i've ordered them. Many thanks for the ebay search. Trouble with a lot of these is knowing what to type in.
        • ffee
          • Nov 2013
          • 8
          • Country: Lithuania
          They are cheap, but they make a hell of a difference. Deff a must-do. You can also try to look at your local radioshack type stores. They should have them in stock.
          • montyrs2
            • May 2008
            • 522
            I have ordered a bag of 100 so I will have plenty I can share with forum members.
              Click HERE
              I'm not sure that's right, my RS2 clocks had them in, as did the RS2 aux instruments I got from someone else in Germany - could be a coincidence, however In all the pictures I've ever seen of RS2 instruments illuminated they look redder than the S cars which have a slight orange tinge. Yes KATE does not show a part number for them, BUT I can think of many other instances where KATE is wrong about the RS2. So maybe, maybe they are supposed to be there
              • montyrs2
                • May 2008
                • 522
                I'll endeavour to take a before and after picture. Main issue was knowing what to search for.
                  When I recently re-lamped the main clocks of my two urS6 Avants, in both cases, all bulbs were white, the only bulbs with coloured rubber covers were a red one in the top centre square that shows the OK symbol. And right beside the red one was an orange rubber capped bulb.
                  My tuppence for this thread, HTH.
                  • ffee
                    • Nov 2013
                    • 8
                    Filters on the check system bulbs have to be there from factory, no question about it. And they're pretty solid too, since the bulbs are 2W, compared to the rest, which are 1.1W/1.2W.
                    • mdz
                      • Jun 2012
                      • 775
                      • Country: Latvia
                      That's how is supposed to be on A/S6. Lighting on 100/S4/B3/B4 is orange. I have these ebay caps on my S2 cluster. They're not as clear red as C4 A/S6 or newer ones, but definitely worth it even considering they cost less than a beer for one cluster
                      • s2driveruk
                        • 12696
                        Di you manage to get a before after photo? In the process of re-bulbing my dash and switches as time has made them very dull LOL
                        1992 3b S2 Coupe
                        • montyrs2
                          • May 2008
                          • 522
                          Dash came out yesterday so should be back in at the end of the week so I will be able to put up an after pic.
                          • s2driveruk
                            • 12696
                            cheers
                            1992 3b S2 Coupe
                            • montyrs2
                              • May 2008
                              • 522
                              Very hard to take a picture in the dark.
                              Main thing is the white light bleed around the needle centers has gone. It is a bit dimmer but that's not really a problem as gauges can be clearly seen. Thought I had a before picture but can't find it at the moment.
                              I prefer it with the caps though just because there isn't the white light bleed.
