audi a6 4b multifunction steering wheel
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    has anyone experience with swapping a normal steering wheel to a mfsw ?
    the car is a audi a6 4b year 2002 with a fis in dash and a rns-d radio
    i placed a mfsw in the car and look with vagcom where to adapt some codes
    but do not find much to activate and the steering wheel buttons do not work
    should something be changed on the steering column wiring ?
    thanks
    nick
    TWINCHARGED power,zero lag
    AEM W/M injection
  • gib
    • Jul 2006
    • 42
    • Home: Wales Current: United Kingdom
    On some models you do need an additional mini harness but I researched this a while ago for an A3 (similar setup).
    Google search on "Forum retrofit RNS-e". Obviously you have a -d but there is far more info available on -e and the logic is the same. I found a lot of links ( Rosstech Wiki is good for codes) and step by step instructions unfortunately I haven't kept them American Audi / Sat nav forums were easy to find and had concise write ups.
