Fuse 20
  • Mikes2
    • 1704
    Fuse 20
    Car is a MY94.
    Discovered today that fuse 20 (after run fan ) was missing.
    Shorting the wires together for the sensor on the water rail, started the fan running s expected.
    Car does not have air con. Has anyone else got this fuse missing or should it be there.
    Mike
    http://www.s2-audi.co.uk
  • Larry Carr
    • Feb 2005
    • 63
    Do you mean the after run water pump, or the low speed fan for the radiator? The 2 pin sensor on the water manifold controls the electric water pump.
    L.Carr
    • Bibby
      • Aug 2004
      • 1043
      Hi Mike, Karlos from Audifans.
      Have just checked my avant, it does have that fuse fitted.
      acidtrax
      • Mikes2
        • 1704
        It also switches on the radiator fan at speed 1, hence the question regarding a fuse in this location.
        Karlos: Thanks for the info. I've added a fuse to this location.
        Mike
        • Larry Carr
          • Feb 2005
          • 63
          Sorry Mike, my mistake. I guess you learn something new every day! I think I'm gonna love this forum! :-)
          L.Carr
