LED Interior Lights
    O.K here's the summary
    Boot / Visor are 11mm x 38mm Festoon: Bulb ID = 239 (272 in some cases)
    Centre Lights Front and Rear are 11mm 42mm Festoon: Bulb ID = 264
    • Jas11n
      • 5067
      Originally posted by Jamo
      i wasn't expecting that!!!!
      How do you take the visor apart to get to the bulbs? simple flick of a screwdriver?
      Pull the visor down and leave the mirror flap down, you'll see on the bottom of the mirror flap two very small notches either side, just get a terminal screwdriver in and ease each side out a bit at a time. The whole mirror front just pops off to reveal the bulbs and light switch behind. Put it back on the same way, ie leave the mirror flap closed as you may damage the switch behind.
      Jas
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • s2avant
        • 2426
        Bit of advice on changing the visor lamps to LED.
        I did this on my avant a while back and the LED version is wider than the filament lamp. This means the LED touches the metal reflector which is also the earth for the lamp. Cue blown fuses.
        All you need to do to fix it is wrap a small piece of insulating tape around the widest part of the LED cap and all is fine.
        Ben
          Ben
          Funny you should mention that as my fuse blew today and now the left side of the lamp wont light up
          • A80Avant
            • 10873
            • Country: Greece
            #20
            hey,i also bought some leds to fit on the rs2.Also got me some extra to fit for the footrest area.Can anyone tell me where should i make the cable connections for the foot leds to work with the rest of the interior lighting?
            a pic would also be nice!
            cheers
            • rs2cabrio
              • 79
              • Home: Germany
              #21
              Hello,
              I made also LEDs in my car. I took all Lights of the new Audi A8, the light is cold white, I like that much:
              made floor area light of the new A8 in front and back, door light of the new A8 etc.
              here are some pics:
              Christian
              Audi rs2cabrio (in work) :mischeif: and alot other stuff
              My Audi Cabriolet
              • Jas11n
                • 5067
                Very nice Christian
                Have you got the part numbers for the interior handle lights from the A8 and also the ones that light the floor area? or a link to what you used?
                Jas
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  hello christian!
                  im using your car as a model,i just didnt buy A8 leds,i bought some aftermarket ones,which i didnt mind,as they are going to be placed in places not noticable.Im interested in the light output.
                  Do you have any night pics with the footleds lighting up to see them?
                  Also thanks for the cable pics,im definitelly going to need them!!!
                  cheers!
                  • Robatron
                    • May 2004
                    • 1168
                    I'm looking to replace by interior lights but I can't seem to find any of these 11mm x 42mm dome festoon bulbs...
                    Could anyone point me in the direction of the correct bulbs?
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      after a while i got back to using the original bulbs in my car.the leds i had bought were not bright enough and sometimes intermittent.Im afraid i cannot do the perfect job christian did to his car so...
                      • Robatron
                        • May 2004
                        • 1168
                        Where can the original bulbs be bought from?
