Odd things going on yesterday! Not driven the coupe for a few days, its been parked up on the drive. Got home from work yesterday (I walk) and noticed an odd scratching / sqeaking sound coming from the engine bay. I grabbed the keys to have a look, but the remote locking not working, so opened the door on the key and turned on the ignition, volt meter didn't even flicker. Battery is flat. In the engine compartment the scratching/sqeaking sound is coming from the Toad siren. I unplugged it and the disconnect siren bleeped a few times really quietly then stopped.
So I grabbing my Ctek and plugged it in, I figured I'll charge the battery up and then test to see what has discharged it.
As I turned the charger on all kinds of weird **** kicked off! Pretty much every system on the car started pulsing, the interior lights were pulsing on and off, loads of relays were clicking under the dash, indicators were pulsing, dash lights, climate headunit, our old mate the Toad siren started doing its scratching, squeaking routine and the after-run pump was pulsing! WTF, my car is possessed!
The volt meter still not registering anything at all. Took the negative terminal off the battery and it continued so the charger pulses were kind of going straight through the battery. Never seen anything like that before, so I'm really none the wiser, I wondered if the battery itself might have a damaged cell internally? It won't take any charge anyway. It was the first thing I bought for the coupe when I bought it almost 8 years ago, so its done pretty well - Varta Black series. Previous to this I had never had any issues starting the car and I could leave it parked up for 2 weeks and come back and it would start first time, up until I last drove it which was Tuesday evening.
I've ordered a new Varta Silver 096 anyway, will get that fitted and see what happens.
My milkman said, how come your lights are always flashing. I now have less money, and a spare battery.
