My audi S2 wont start!!??? :( need help!
  • eXtreemeRS
    • Feb 2005
    • 56
    Hi!
    Got a Audi S2 2,2 turbo 92mod.
    The car just stopped one day..I suspect the electric..
    It seams like the brian of the car dosent get 12v power..
    Anyone got a manual of the wiering form the fusebox and out??
    The fuel pump should start for a few sec when I turn the ignition on..
    I dosent.. There is no sparkel out from the coyl..
    But I can open the rele for the fuel pump and start it manualy.. then I can hear the fuel pump start.. but the car still dont...
    hmm... anyone got any idea here... I WANA DRIVE!!!!
  • merlin's S4
    • Jan 2005
    • 1539
    I had a similar situation with my '93 S4 recently, it got me really worried for a minute and then I remembered something I saw on some website or other. On the S4's there is a 5 amp fuse next to the ecu which supplies the ecu's power, I changed the fuse and as if by magic the car fired up first time! Not sure whether the S2 is the same but it's worth a look!
    Hope you get it sorted soon!
    • porkkis
      • 1994
      No fuses near the ECU.
      Did the car stop while driving or just one time did not start?
      If it did not start, I guess the hall sender is #1 choise.
      If it stalled while driving there are plenty of choises, unfortunately.
      Check the fuses at the fusebox below the red "motor" fuseholder. If a fuse is blown you have something wrong as they're not there just to blow and to be replaced...
      Our cars do not prime the fuel lines, the pump runs only when starting/running.
      The fuel pump relay feeds the ecu and is signalled by the ecu, neat, huh?
      One pretty common thing is a distributor gear failure. Take out the dizzy cover and try to turn the rotor. If the dizzy gear is dead, the dizzy wont turn and then the hall is not correctly aligned and that means no ignition at all. I guess no fuel pump feed neighter.
      HTH
      • jeroen
        • Aug 2004
        • 100
        sounds more like an ignition key elec part!(dont have a cleu what you call it in inglisch)but it is situated behind where you stick in the key in the ignition !
        • eXtreemeRS
          • Feb 2005
          • 56
          hmm..
          Yeah.. I can check behind the ignition key... just to check that everythig is
          ok.. is there any fuses behind there?? or any rele's?
          • porkkis
            • 1994
            In '92 cars the only option for factory immo was a system called "conlog". This had nothing to do with the ignition switch.
            I'd say that the dizzy gear went south.
            • jeroen
              • Aug 2004
              • 100
              i know but am not talking about an immo! just the switch!
              • porkkis
                • 1994
                I'm blind, sorry.
                • audi660
                  • Jan 2005
                  • 162
                  • Country: South Africa
                  Hi there,
                  I've got the exact same problem with my s2.
                  If you find out what the problem is, please let me know.
                  It's so frustrating!!
                  [SIGPIC]1997 Ur-S6 SMS Revo S
                  • quattronutter
                    • Jan 2005
                    • 690
                    best bet is to get it hooked up to vagcom to check for any faults ....
                    • audi660
                      • Jan 2005
                      • 162
                      Can't get into the ecu with the vag...
                      Looks like the ecu isn't getting power
                      • quattronutter
                        • Jan 2005
                        • 690
                        sounds like an ignition fault,best check all the ignition wiring for continuity,does the engine turn on the starter or is it totally dead?
                        • audi660
                          • Jan 2005
                          • 162
                          The engine turns but there's no spark and the fuel pump also doesn't switch on..
                          • audi660
                            • Jan 2005
                            • 162
                            Found the problem.. A 20A fuse was blown in the fuse box. It's in a pink holder and is fuse 32 for engine timing 3.
                            Still not sure what caused the fuse to blow.
                            Any ideas?
