So having checked for continuity from vss plug to speedo plug and getting a good connection, plus getting a good 12 v at the vss plug, I'm left with two options, broken vss, or cluster
) but the problem was too intermittent to be easily identified.
) but the problem was too intermittent to be easily identified. You do not need to remove the box. Just remove DS axle, drain the oil and remove the side cover with CV flange. Not a common problem, but i know it has happened before.
Just to confuse things, the difflock is disengaging as it should, plus the trip counter is working , I'm confused now as both those get there signal from the vss, or am I wrong ?
