Are Elipsoids RHD/LHD specific? (I may have bought a pair in error)
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    So I had this cunning plan to try fitting elipsoids in my B3 (yes, yes. when I go and collect it from Kit in Wales). Based upon this thread http://www.s2forum.com/forum/showthread.php?t=52559
    Because Finland is quite dark half of the year and standard coupe/cabby/80 headlights are ****.
    But after sourcing a pair I've realised my cunning plan may be flawed. Because they came from a RHD car and mine is LHD.
    Sooooo... what I'm asking is whether I've been a dumbass and bought a pair of elipsoids that won't work in a LHD country? Or are they switchable like my nice A4 lights?
    If I have been a dumbass then I will probably have a pair of elipsoids for sale rather soon.
    cheers
    1990 CQ20v
  • Nuvo
    • Nov 2003
    • 3826
    I'm afraid you've made a boob Noel. You need specific LHD units for your country.
    • Nj
      • Jan 2007
      • 3420
      ah nuts. answered my own question. they are changeable but requires cutting and welding. I can't weld and i'm most likely to make a bollcks of it and ruin a perfectly nice pair of elipsoids.
      looks like these are for sale then.
      doh!
      1990 CQ20v
      • Nj
        • Jan 2007
        • 3420
        haha. yeah. sounds like it Rob
        1990 CQ20v
        • Nuvo
          • Nov 2003
          • 3826
          How are they changeable? The reflectors are fundamentally different.
          • Nj
            • Jan 2007
            • 3420
            "with difficulty" I believe is the answer
            Forgot the link in the last post
            1990 CQ20v
            • Nj
              • Jan 2007
              • 3420
              And I'm back to wondering how the hell I can improve the headlights in my CQ20v
              1990 CQ20v
              • gavs20v
                • Sep 2004
                • 3057
                There is a lever on the back of the headlight which flattens the beam ( not ideal )
                A set of HID's will do the trick as well as simply polishing the lenses
                Gav
                S2 Cabriolet.........
                • Zoig
                  • Sep 2008
                  • 555
                  AFAIK there should be markings on the glass indicating that they are ment for RHD cars, if someone is smart enough they could figure it out during the car inspection.
                  Retrofitting aftermarket ellipsoids into the light should do the trick (2.5" Mini H1 for example) and get you a correct beam pattern, but you would need to figure out how to mount them properly with adapters to the stock mounts or something similiar.
                    relay the headlamps
                    • GT500
                      • Jun 2006
                      • 2181
                      I can swap them over to lhd. Quite involved but is as it should be.
                      Rob..
                      87 UR 20v ABY
                      97 S6 Avant
                      • quattrodave
                        • Dec 2008
                        • 218
                        OK I'm confused as I thought the RHD and LHD elipsoids had the same lenses (as in main outer lenses) but the difference was in the elipsoid unit fitted within the headlamp there is a LHD and a RHD version where the cutoff is in effect opposite like viewing in a mirror ? I believe this is where GT500 does the work to cut and reweld the cutoff part to convert ? (correct me if I'm wrong) as I have LHD elipsoids on my car I swapped 2 RHD inner elipsoid units from an early (might have been late 100) pair of A6 hella RHD headlamps to convert mine so I have 2 x LHD new elipsoid lens units spare.
                        • GT500
                          • Jun 2006
                          • 2181
                          Yes dead right. Lenses are the same. All done within the elipsoid unit.
                          Rob..
                          87 UR 20v ABY
                          97 S6 Avant
                          • Nj
                            • Jan 2007
                            • 3420
                            thanks for your input gents. All thoughts of alterations are truly out of the window as the original seller of the units just told me he had a good offer for the whole car and took it. refund for the lights coming my way (and other bits I had agreed and paid for). sucks balls.
                            so anyway, HIDs. I can't fit those in a standard reflector headlamp unit can I? Only in projector units?
                            cheers
                            1990 CQ20v
                            • martinjs
                              • 3205
                              The spot welded parts are handed, so need splitting and swapping about.
