Strage Electric Problem
  • Simons
    • Jul 2007
    • 530
    • Country: Spain
    Thanks! I only need time...
    • Simons
      • Jul 2007
      • 530
      • Country: Spain
      well, I didn't find the problem yet...
      I changed the fuse box, disconnect the alternator, unplug the ecu, unplug the ignition switch connector, remove all the relays and fuses...and the problem still alive.
      I check the voltage on pin 15 ignition switch connector, I have between 8,4 and 9,2v....I don't know who is fedding the +15 line(powered by ignition switch), but isn't on the fuse box or relay...I think is some damaged part who has always 12v
      Any ideas??
      • A1QSHIP
        • Aug 2004
        • 975
        Ignition Switch
        This
        "Nulla tenaci invia est via"
        • Mikes2
          • 1704
          Disconnect the starter motor
          Mike
          http://www.s2-audi.co.uk
          • Simons
            • Jul 2007
            • 530
            • Country: Spain
            #20
            Tomorrow I will do it. Thanks
            • Simons
              • Jul 2007
              • 530
              • Country: Spain
              #21
              I still with the problem....I must study the schemes
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #22
                if there is install some products not origional of the car i woud disconnect those things like alarm-radio-phone system-gps-remote control for the door locks-..............
                otherwise you need to look at the electrical diagrams to see which relay or ecu gets bat+30 and contact +15 so you can disconnect some to see if the problem is solved
                it can be your dash itself-airco panel-central locking pump-airbag-the rest off the ecu's .................
                i hope this will help your problem
                TWINCHARGED power,zero lag
                AEM W/M injection
                • Simons
                  • Jul 2007
                  • 530
                  • Country: Spain
                  #23
                  Thanks mate, this is what I was doing...I still need to remove abs ecu, aircon panel, central locking pump, diff lock, servotronic...I need time to do it, I'm very busy
                  • Simons
                    • Jul 2007
                    • 530
                    • Country: Spain
                    #24
                    Finally I found the problem
                    I disconnect all what it have under the rear seat...nothing changed, so I decided to go again with the fuse box and disconnect the coloured plugs, when the black one was unplugged all the problems disappear, I checked for voltaje and I found 9v on the black/blue wire, bingo!! I thought
                    I removed the wire from the connector, connect it to the fuse box and fire up the engine, perfect. All works fine...lights, clima, dash,...so I decided to let it out
                    The schemes said that must be two black wires, I think that BK=black, but there is one black/blue...like they show on the blue plug for the flasher, light switch and cruise control... the wire position in the black plug said that the wire who I removed is for the reverse light switch, but the lights works fine
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      #25
                      great
                      maybe there is a fault in the fusebox?
                      AEM W/M injection
                      • Mikes2
                        • 1704
                        blue / black is switched 12v. goes all over the car via fuse 12
                        Mike
                        • Simons
                          • Jul 2007
                          • 530
                          • Country: Spain
                          #27
                          Originally posted by quattro-nick
                          great
                          I changed for another one...and nothing changed
                          I removed all the fuses and relays and the problem continued
                          Today I drove the car and I found one thing that don't work...the servotronic
                          • Simons
                            • Jul 2007
                            • 530
                            • Country: Spain
                            #28
                            I drove the car today and the servotronic works fine, all goes well after removing the wire
