I've been trying to find the cause of an electrical woe for a while and it's been getting progressively worse. It started in that after 3 days of not driving the car wouldn't start as the battery was dead, turn the key, lights come on briefly but dim, click, click, click, nothing.
Charge the battery and it's fine, jump from a pack when flat and she is fine.
Gradually it's been getting worse and worse and I've this is what I've covered:
- checked fuses
- replaced battery
- check central locking pump for over run
- had a garage check for a drain, nothing found
- disconnected everything non essential, stereo, sub
- once started she sits at 14v on the VDO, so alternator seems fine
Where to look next please? Alarm? Ignition? Other ideas?
I'm at a loss at the moment and I the battery is rinsed overnight now
- checked fuses
- replaced battery
