Took my QC20v for a jaunt today, got going down the road and the drivers window not operating. finished taking it out for a spin and had a look around to find the fuses. now i know it works because last week when i was washing it windows, both, worked fine and now drivers window wont play so i'm guessing its a fuse right, well thats where i'm going to start before i start taking door cards of and seeing inside but where are the fuses for the windows. Not under the bonnet not behind the facia under the steering, someone steer me in the right direction please. Cheers
Hey Dude wheres my fuses?????
I just checked some 7A info that I have shows a fuse box under the hood, much like the S2 or RS2s.
RS2 Fuse Box
Attached FilesRS2'd 93 UrS4 5 spd sedan
Try this: http://www.audifans.net/ftopicp-186916.html
It might be the yellow thermal fuse (white arrow) or the 367 control module (red arrow) in this photo from the post linked above
7A has the 284 window relay and the thermal fuse is plated steel, so grey.
If it's only the one window playing up I'd suspect the door switch or motor. Relay or thermal fuse problem would tend to knock out all of them. HTH
Imola B6 S4 AvantComment
Window relay under (above) driver side glove box to answer the question
May be switch as said above but could also be frayed wires in concertina rubber
by door hinges.Comment
