So... I calibrated my trip computer according to S2central.com. In my opinion the procedure described on that page is not entirely correct. I got the instructions from Audi Sweden. There are similaritys but they also differ.
First off. The fuel guage should not be set to show full at full tank (!). When the service tool vw1301 in set according to the instructions the guage should be set to point at the third red bar.
Next thing - calibrating fuel reserve. When using the vw1301 tool the trip comp should show the number 80. This number is the same for all S2's, regardless of model (Coupé, Sedan or Avant). It stated on S2central that this reading is how much fuel you have in the tank. That might be - but I don't believe it since the reading should be the same regardless of model - the tank size differs from Sedan/Avant and Coupé (checked it on my buddies RS2 - it basically implies that the sedan has a bigger tank than it actually has).
Maybe the S2Central way works - I can't say it worked all that well for me though.
I'm going to round up the mentioned service tool and check how it works - if anyone wants a write up on the full procedure I'll try to translate the Audi manual on it.
And - I did not write this to bash S2Central - I tried the method described on there, I wrote a mail asking for more directions...and then I contacted Audi Sweden. A very fast reply from them, they sent me the instructions... All I need now is the VW1301 tool.
