Indicator relay position
  • diesel des
    • 3896
    So where does it hide out? I'm doing the loom in my urq with s2 engine loom and am trying to work through the mess of wires at the moment.
    Cheers.
    That one sits in around the steering column on from memory - so you can hear it go click-clack etc - somewhere between the upper trim and the instruments. Look for black 4-pin relay holder in that area - should be close to the blue and green 26-pin plugs for the cluster on the S2 loom.
    • bluequattro
      • 2960
      Is ur original one behind speedometer like a gt?
      • diesel des
        • 3896
        Thanks guys think I have it now. Found a 3 pin connector in and around where the clocks used to live. In the same loom that runs up to the switches for lights etc around the clocks.
          I know this is late but Item 19 in this 7Zap illustration: http://audi.7zap.com/en/rdw/audi+cou...971-971088/#19 PN: 431953231
          • diesel des
            • 3896
            Cool cheers.
              Cool cheers.
              Ekaterina's photo of the Item 58 three pin connector. Not sure how this works with a 4 pin relay.
              • diesel des
                • 3896
                I'm sure I will find out tomorrow....
                • diesel des
                  • 3896
                  I can confirm the urq relay is indeed up at the dash clocks area with 3 pins only.
