Aby battery cable routing
  • gavs20v
    • Sep 2004
    • 3057
    Morning ,
    Apologies if I missed a previous thread however I couldn't see one when I did a quick search.
    Can anyone offer pictures and details of how the power cable routes through the car and off side wing on an aby coupe please ?
    I'm retro fitting an aby battery box
    Thanks in advance
    Gav
    S2 Cabriolet.........
    • 12431
    Gav from memory it runs along side the procon ten cable along the edge of the sill and passes up into the under seat area at small gap where the seat base meets the door card
    • gavs20v
      • Sep 2004
      • 3057
      Thanks Greg ,
      Any ideas on how it routes from the foot well in the engine bay ?
      • quattrostyle
        • Oct 2006
        • 6229
        On a LHD S2 it runs from the passenger side footwell area through a grommet and inside the chassis leg from there, then it leaves the chassis leg somewhere halfway through a grommet and enters the engine bay. Can imagine it may be different in a RHD car as the pedals sit there as well so probably not of any use
        • gavs20v
          • Sep 2004
          • 3057
          Lol I'll have a route around and see what I can find
          Gav
          • david1980
            • May 2014
            • 1028
            On mine it went from under the rear seat across and down the drivers side to behind the accelerator pedal and down inside the chassis leg and came out underneath the chassis leg
            • quattrostyle
              • Oct 2006
              • 6229
              so it actually is the same on RHD cars
