Retrofit trunk release with button or remote to C4
Hello,
i would like to fresh my extras a bit.
Unfortunately i haven't found a schematic about it.
What should i need if i want to open my trunk from inside with a button?
Haven't found a factory schematic about it.
Depends which pump you have but assuming you have the twin vac it will be quite easy
I retrofitted a twin pump to my coupe using an A8 diagram
E164 is the interior boot release switch and I used a cheap ebay solenoid with relay to open the lock, I'm sure the pump output is V53 (from memory)
This will allow you to use a three button remote, but I still haven't figured out how to open the boot without the alarm going off, however this maybe different with the A6 wiring and boot switch
