Instrument Cluster Change PROBLEM
  • Bullysteeth
    replied
    All sorted in Rugby Thanks for the replys and help
  • Bullysteeth
    replied
    Thanks pal, I just need to find someone more pc literate than me lol
  • M2ki
    replied
    You use that same linked vag tacho cable and software to read pin from "new" cluster.
    Also you need vag com / vcds to read coding info from old cluster and later use that info to code "new" cluster.
  • Bullysteeth
    replied
    Thanks pal, its says in the tech that I need the four pin code from the new unit, That I don't have
  • Dynasty
    replied
    Seach for vagtacho on eBay. On the older Audis the security pin followed the original keys (small label).
    http://www.ebay.com/itm/Latest-Versi...YAAOSwJ4hY9B0c
    The instruction on how to pair up the new cluster is found here: http://wiki.ross-tech.com/wiki/index...r_Generation_2
  • Bullysteeth
    replied
    Trying to find someone in the Midlands who can is proving a task in its self lol
  • M2ki
    replied
    Originally posted by NZSPQ
    Hi,
    if you can still get access to the orignal ecu (from the car the cluster came from, you can either swap out the ecu, or just desolder the immo chip from the matching ecu and solder into yours. Done it several times on ecu swaps..
    Ecu waits for a OK signal from immo (cluster), if you take immo and ecu from donor, then you need keys also (immo chip from fob) from the donor car.
    If you are soldering stuff already, then it is easier to make immo off from ecu.
    Ask help from somebody who has vag tacho and vcds cable and can use them.
  • NZSPQ
    replied
    Originally posted by Bullysteeth
    HI guys
    Sorry its not a S2 but it is a S4 b5
    I need to swap my clocks over, I have a replacement set that's all working unlike mine
    Now in the S4 the clocks are programed to the car and it will not run with the replacement fitted
    Can anyone help with this
    Thanks guys
    Hi,
  • Audicted
    replied
    Originally posted by LHD_Kid
    The more modern the Audi.... the harder it gets...
    This is the kind of stuff that makes me keep fixing my old cars
  • LHD_Kid
    replied
  • Bullysteeth
    replied
    Sounds hard guys
  • M2ki
    replied
    You need vag tacho or similar to read PIN from old and new cluster. After you have pin codes, then you can adapt with vag com / vcds.
    replied
    You can do some stuff in the cluster on vagcom, not sure what though
  • M2ki
    replied
    Immo is in the cluster, vagcom can't help you.
    replied
    I expect you can recode with a vagcom. Probably worth checking in the Ross tech wiki
