Melted fuse
yup - thats just what mine was like.
I bought a couple of connectors which looked right from etka but none fit. Eventually pulled one off an 80 which did fit the fan connector and bought a new one from audi with matching wiring kit. Sorry - didn't keep hold of the p/n.
Fingers crossed the p/n is right for yours - afaik, there was a different fan for model years and w/wo A/C.
G. luck!
yes - a bit like that - but a wider plug with a quick release locking tab and certainly thicker cables considering the loading!Leave a comment:
here you go...VAG's finest work after it went in years ago when the fan shorted causing the fuse plate to melt. Final bill was over £500
Attached FilesLeave a comment:
Excellent, thats MUCH appreciated. Still can't believe the bodge that was there...!Leave a comment:
David, I think the part numbers you need are 893 906 232 (3 pin connector) and 191 927 907 (protective cover).Leave a comment:
in that case thats sh*te work by Guildford Audi about 4yrs ago then, i just have 3 spades on the fan connectors. Any ideas what the block part numbe ris and as I currently have the rad out i can make one up to fit.
cheers
davidLeave a comment:
pretty sure mine is a connector block that plugs in to the fan, not separate spades.Leave a comment:
ditto. Can anyone confirm on a 3b fan how many connectors they have. I have 3 connectors on spades rather than a block conector, is everyone elses the same?Leave a comment:
Found it on the 20v website:
Originally posted by http://www.20v.org/engprob.htm
(Scott Justusson)
In later cars, Audi put an 80 amp fusable link into the ground wiring for the radiator fan. This setup is used to avoid sending 80+ amps of 12V to the fan ground if the fan bearings freeze up . This could possibly cause an electrical fire, or at a minimum it will fry your electrical harness.
Here are the Audi P/Ns for retrofitting a ground fuse to the fan wiring:
281 937 505 A = fuse box
N 017 125 3 = 80 amp fuse
443 971 845 AM = mounting bracket
N 014 128 11 = screw (x2)
N 012 005 3 = lock washer (x2)
N 011 556 2 = washer (x2)
N 013 966 12 = screw (x2)
Or, you can install a generic fuse (60 amp should be fine, and it's easier to find than 80 amp). If you ever blow the fuse, you need to get a new fan motor ASAP.Leave a comment:
I think I read this too somewhere (maybe here) but can't remember where.
The attached diagram is for an Audi 80 so I can only guess that later coupes also had this revised arrangement.
You can see that S42(S5 on first diagram) has been uprated to a whopping 60A, you can see the fuse and the second speed fan relay J135 (J101 on first diagram) are now mounted externally from the fuse/relay board.Attached FilesLast edited by Nuvo; 19 June 2007, 10:09.Leave a comment:
