Lambda Probe question
  • pjeast73
    • 144
    Hi all,
    does a faulty lambda probe show up on vagcom? My fuel consumption has dropped by 1-2mpg and I feel a very slight 'surging' at constant throttle and a very slight fluctuation in rpm at idle.
    Is the lambda the first likely suspect? Anyone know the price of these? Are they from Vagparts?
    And if I do proceed, if this an easy job - or am I going to see Tim (QRSports) again?
  • rotoryboy
    • May 2004
    • 3281
    I would clean your MAF and ISV first
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • pjeast73
      • 144
      just picked up a bottle of IPA - plan on doing the MAF tonight. what's the ISV? and where is it? and how is this cleaned? is there a thread already on this. I'll try a search. thanks
      • pjeast73
        • 144
        OK - the search came up with - close one end and spray WD40 into the other. is this correct - but still don't know where it is (ISV). can anybody help on this. will aim to do both tonight.
        • Billman
          • 4129
          Idle Stabilization Valve! It is a round thing near the Inlet manifold at the back of the engine!It has 2 hose connections and a cable!
          Go Holset or Go RS4
          • rotoryboy
            • May 2004
            • 3281
            This is the ISV
            Mark
            Race Clio RS197
            • pjeast73
              • 144
              thanks guys! will report back if these make a difference.
              • porkkis
                • 1994
                Bad lambda tends to enrichen rather than make it run lean.
                • pjeast73
                  • 144
                  ah - bad wording I think on my original post. What I meant to say was - I am getting 1-2 miles less per gallon.
                  • porkkis
                    • 1994
                    I'm a bit lost with your measure units every now and then and now again
                    • BrianSmith_S2
                      • Jun 2005
                      • 1342
                      • Home: Northern Ireland Current: British Antarctic Territory
                      cleaning ISV
                      Hi, visit 20v.org/engprob.htm for a good guide to cleaning the ISV. Its for the 20v 7a engine but the same guidance should work for your car.
                      • dan_b
                        • Sep 2003
                        • 3670
                        @Pjeast
                        A bad lambda does indeed show up on VAGCOM, and also gives you exactly the symptoms you've described: rough running, surging/hesitation at constant throttle, lumpy tick-over and less boost. I know because I've just had the same issue - you can read my thread here if this helps
                        New Lambda probe is a doddle to fit: from VAGParts a genuine item is about £70 inc VAT and delivery. Worth cleaning your MAF and ISV as well though!
                        Good luck, let us know how you get on.
                        • pjeast73
                          • 144
                          Cheers Dan (and everyone else). Going to order a new Lambda from Vagparts - hope they can get it me quick and I'll fit this and do the cleaning at the weekend. Dan's thread does sound a lot like me - so fingers crossed.
                          • dan_b
                            • Sep 2003
                            • 3670
                            VAGparts took about 7 days to deliver the probe to me. Apparently you can get generic ones from other suppliers, but I don't know anything about that.
                            Good luck!
                            • martinjs
                              • 3205
                              Dont bother with those, BTDT and it was a right joke. Stick to OEM.
