I followed a link about homemade pressure test kit. The part cost me under 2 notes from B'n'Q, deal. Did the markH mod, 27 notes, bargain. My O ring was twisted and about 3 times the original size. The car was just slightly leaking from somewhere near the butterfly.
The question is, link said plug the pressure tester into MAF hose and pump and listen, but with out putting a stopper into the pipe that comes from bottom of the inlet to the turbo, through a T-piece, one part of the T to the bottom pipe of the WGFV and the other part to the air box, you can pump all day as the pressure just gets released out of this? I'm i missing somethink here or is that right
Thanks to all
Martin.
Thanks to all
Martin.
