What are the standard boost figures ?
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    Hey gurus
    I have just installed a boost gauge and wanted to check that all is well with my new toy, so below are the readings I saw when I went for a quick blast (not accurately recorded so working from memory here)
    Idle = -0.6 Bar
    pootling (1000-1200rpm) = -0.8 - -1.0 bar
    peak full boost in 1st and 2nd (3000 rpm = 0.8 - 0.9 bar (drops as revs rise)
    full boost in 2nd (6000 rpm = 0.5 bar (I think)
    peak full boost in 4th and 5th (3000 rpm = 1.1 bar (holds for a while before dropping)
    So, am I healthy?
    cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    Smells about right there for a stock ABY.
    • HPmuirt
      S2Forum April Fool
      • Apr 2005
      • 3014
      Thanks Paul, that's good to know
      I assume the higher boost in 4th and above is overboost, so I guess that all is well with ma toy
      Cheers n
      Si
