Help Hesitation/missfire
  • charlie
    • 447
    Just rebuilt my engine. Problem is when i decide to have a spirited drive, at high revs in low gears on WOT, it tends to hesitate and and blackish smoke exhausts out.
    But if i take it easy or when outside temps are cooler with progressive throttle it drives fine. Not had it re-mapped since i had Cat-bypass, and cone filter as i pressumed the ECU would compensate. Planning to get it mapped by Minhea on his next visit to UK.
    But i need to make sure everything is perfect first.
    Any input would be appreciatted.
    RS2 MTM
  • BRY
    • 3755
    Do you have boost gauge?
    What is that showing?
    • charlie
      • 447
      peaks 25psi at about 3500rpm then holds it all the wy to the redline.
      RS2 MTM
      • charlie
        • 447
        Anyone
        RS2 MTM
        • mastermind
          • Jan 2005
          • 244
          • Country: South Africa
          Maybe spark plugs breaking down, or coil pack or suppressor or the spark amplifier.
          The Red Baron
          (R)S2 spec, 034 GT3071
          Wagner Short Intake and Intercooler
          Whiteline, Custom Shocks with external reservoirs
          8pot calipers with A8 discs
          Vems
          • charlie
            • 447
            [QUOTE=mastermind]Maybe spark plugs breaking down, or coil pack or suppressor or the spark amplifier.[/QUOTE
            Hi Mastermind,
            Spark plugs newish. What do u mean by suppressor?
            RS2 MTM
            • BRY
              • 3755
              How many miles has it done?
              What oil are you using?
              Could be the coils are worn out, and the oil is escaping past the seals in the turbo.
              • charlie
                • 447
                MILEAGE : 102,000
                OIL : Castrol RS 10-60W
                TURBO : PERFECT BACK FROM AET ENGINEERING
                SMOKE : black smoke not blue which suggests overfuelling. not burning oil
                Software problem or ignition(coil pack) ???
                RS2 MTM
                • dan_b
                  • Sep 2003
                  • 3670
                  What age is your car - is it a 3B or an ABY?
                  Have you got access to VAG-COM, have you checked to see if its logging any fault codes?
                  Has the lambda probe been changed recently? My car was running badly recently, turned out to be just a simple worn lambda.
                  • charlie
                    • 447
                    Strange, I noticed car running better on regular unleaded than on super unleaded.
                    How could this be. Could the MTM software favour 95 ron to 97 ron?
                    RS2 MTM
                    • dan_b
                      • Sep 2003
                      • 3670
                      MTM chip definitely wants 97RON, my car usually runs very retarded on 95, a noticable loss of power.
                      • charlie
                        • 447
                        How Do U Test/check Coil Pack And Amplifier???
                        RS2 MTM
                        • mastermind
                          • Jan 2005
                          • 244
                          I'm Asuuming its an ABY, I had to swap my coils with another car before I realised this was the problem with mine when my RS2 misfired at WOT.
                          Not too sure how to test them but there are other posts on coils and amps which you may do a search for on the forum.
                          The suppressors are the parts that link the individual coils to the spark plugs.
                          Those were cracked on my old urS4 and also caused missing problems.
                          The Red Baron
                          Vems
                          • charlie
                            • 447
                            Cheers mastermind,
                            It's actually an ADU engine (RS2) and symptoms you have mentioned are exactly
                            the same at WOT.
                            Anyone here with a spare set of coilpack and ampilfier
                            It's getting to the point i feel like taking it to QST/Dialyxn
                            RS2 MTM
                            • charlie
                              • 447
                              CHECKLIST:
                              1) Check exhaust camshaft postioning(would this cause high boost misfire)
                              2) Check sparkplugs torque
                              3) Check amplifiers
                              4)replace all coilpacks
                              5) if all fails ???
                              RS2 MTM
