ISV cleaning
  • Keeper of The Kitten
    • Dec 2003
    • 2317
    ISV cleaning
    Hey hey fellow keepers
    Kitty the Koupe needs her MAF cleaned, which I think I can do fairly easily (and I have access to copious amounts of IPA to do the job).
    However, I understand that it is also a good idea to clean the ISV...
    ...but how much of it do I need to remove and clean?
    Do I just need the barrel shaped bit off the back (the bit with the electrical plug on it and the small hoses, held in by the rubberised loop)? Or do I need to remove more than that?
    Help and advice appreciated!
    __MDC__
    Martin Cutting
  • Crawford_S2
    • 1555
    I cleaned my ISV recently, just did the barrel shaped bit with the plug on it. I also cleaned the MAF and the throttle body. One or all of these made the car a flyer again and i now need 4 new tyres!
    BTW i was told to make sure i lubed the ISV after cleaning or it will seize up eventually, I just gave it a squirt with WD40 after it was cleaned with IPA.
    Ragusa Coupe gone!
    • dkw_dude
      • 555
      • Country: Norway
      __MDC__
      Thats all I had to disassemble on my 3B. Three jubilee clips, one on the little TBV hose, and the two on the ISV + electric connector. The rubber thing is quite flexible, now after having done it a few times removing the ISV is a 1~2 minutes job..
      Oops not fast enough..
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
        • Dec 2003
        • 2317
        Thanks to both of you! Will do as suggested when I get hold of the IPA (waiting for one of the composite guys to get back to work on Tuesday).
        Think I need to get WD40 on the throttle linkage too - mine seems to stick just a tiny bit above idle and it causes havoc with the stabilising, especially when hot. Push it back and the idle settles down nicely - but the linkage hardly seems to move?!!
        __MDC__
        Martin Cutting
