ECU fault
  • Taffy
    • Jun 2005
    • 101
    • Home: Wales Current: United Kingdom
    ECU fault
    Hi all
    hope you can help me with this one, posted a message previously about wgfv problems as it wasn't getting any power (or very little) but now i think i have a full blown ECU fault. I used the info in s2central.net to try to pull the blink codes off.
    Was using the same LED everything but when i do it it seems that the LED is just getting a constnt 12v even when the ignition is off. And when i short the circuit for 4 or more seconds the LED still doesn't go out.
    Can anyone help? really don't want to buy a new ecu, is there any tests i can do? Have a multi meter so can do all sorts..
    many thanks
    Taff
  • Taffy
    • Jun 2005
    • 101
    Also when i reset the ECU all seems to be ok for about 30 secs, its the blink codes (or lack of them) that i'm worried about, am taking to a Audi place with a vac-com (sp?) to check if the ecu has gone pop...
    • GandalfS6
      • 332
      • Country: South Africa
      There is a fuse for the diagnostics - check if it is OK! It is Fuse 21.
      1995 Silver S2 (ADU) Coupe
      2006 Porsche 997 Carrera S
      2006 Misano Red RS4
      2004 VW Touareg V8
      2007 Golf Mk1 Race Car
      2004 Mercedes Benz Vito 112CD
      • ~Delta
        • Apr 2005
        • 797
        ... And rest assured, I doubt the ECU is faulty. If the fuse is ok, just take your car to an Audi dealer, most charge very little for a quick diagnostic if they're not very busy (my local dealer didn't charge me at all). That way, at least you can put your mind at rest.
        Never show a fool a half built house.
        Never underestimate the power of stupid people in large groups.
        Life is like a **** sandwich
        The more bread you have, the less **** you eat
        • porkkis
          • 1994
          I think you have wired the LED to the wrong pins. Possible?
