Hopefully someone may know WTF is going on with my bro's car (I'm posting as he is shy and hasn't a clue when it comes to stuff like this
Ok, the car is a 95 ABY coupe, miles are 60k.
The car keeps on getting overboost control coming in. The car has recently had the following; (just to rule these items out)
1/ new WGFV
2/ New Bosch 710N TBV
3/ New Bosch F5DPOR spark plugs
4/ and a recent service with new oil, coolant etc.
Fault codes from Vag-com are,
00544 - Maximum Boost Pressure Exceeded.
...........13-00 Adaptation Limit (Mul) not Reached.
00561 - Fuel Mixture Adjustment.
............27-10 Implausible Signal - Intermittent.
Now, looking up in the official Workshop Manual for the Motronic Fuel Injection and ignition System edition 09.92
It gives the following solutions (the stuff I'm asking for help on)
As I say, the TBV is fine, and I've also tested the WGFV with the output tests in Vag-com, and it's clicking away like a good un.
We've ruled out a boost leak by pressure testing the whole system, which holds pressure quite well.
Would a faulty/dirty G70 (Maf) cause this type of problem, or could it be something like a blocked fuel filter or duff fuel pump (not noisey BTW) which is maybe causing fuel pressure to be to low? again would the fuel pressure being to low, trigger Motronic to cut boost?
What else could cause the fuel pressure to be too low?
Next on the cards tomorrow is to swap Maf's with mine, would this be a good idea?
I've tried to give as much info as I can, just need help interpreting the above possible solutions.
Sorry for all the questions
I'm learning all the time
TIA
Jas
)Ok, the car is a 95 ABY coupe, miles are 60k.
1/ new WGFV
TIA
Jas
