Wide band landa kits? Whats best?
  • diesel des
    • 3896
    Anyone any experience of the wideband landa kist available. Whats the best deals arround? Stuff like http://www.grahamgoode.com/innovate/lm1.html
    And http://www.zeitronix.com
    I am interested in one as are 2 friends so that makes 3. Anyone else interested in a group buy? Thanks,des.
  • Mihnea
    • 1288
    I have the zeitronix one and it works fine. I don't use it very often though, as my main wideband kit from www.wbo2.com is fully integrated in a multi-display with intake temp and EGT displays as well, and this is what I tend to use most of the time...
    Good stuff though, decent people to deal with, and hopefully their boost gauge function is going to work soon up to 3.5 Bar absolute, instead of 1.72...
    HTH,
    Mihnea
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • diesel des
      • 3896
      Thanks Mihnea. The http://www.zeitronix.com unit has a option to do logging of EGT, boost and also Lamda. It seems the least expensive kit to be honest and does most everything i would need and more. I will ask them about the boost limit issue. Anyone else?
      • Mihnea
        • 1288
        Apparently their new units measure boost up to 2.4 Bar relative... that's really good, I'll have to email them to see how I can update my existent unit...
        Cheers,
        Mihnea
        PS: the reason I'm not using the zeitronix unit permanently is because I like to see intake temps as well as EGTs, not only one of them, and their ZT2 unit can't display temps from a K-Type thermocouple under 200°C, so that excludes intake temps...
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • diesel des
          • 3896
          Ahh i see. There is also a universal input, i have emailed them to ask if thats a 0-5volt or what. I may be able to use that with a simple opamp to give me intake temp also. Also i have asked if a group buy will drop the $$$. Will keep you all informed. Thanks again Mihnea.
          • slow2
            • Apr 2004
            • 238
            The universal input is 0-5volt, i dont have anything plugged into that point at the
            moment, sounds like a good idea diesel des
            Dez
            Never did overtime until i purchased........s2
            • repo
              • Dec 2004
              • 893
              If You plan to install an uego permanently into Your car, I recommend AEM gauge type one.
              Also Innovate Motorsport unit has datalogging in this "palm" unit, and has PC configurable 62mm display, but it's a bit pimp if U ask me...
              • diesel des
                • 3896
                Thanks all. Here is what i got back from Zeitronix
                Thank you for your interest in our products.
                You can measure the intake temps in raw voltage using any RTD sensor connected into the User input.
                Thanks,
                Zbigniew
                Zeitronix Inc.
                I will get prices for multiples over the next few days. Thanks,des.
                • raymor
                  • Sep 2003
                  • 597
                  Thanks,
                  Zbigniew
                  Zeitronix Inc.
                  Des,
                  What sort of prices did you get back for volume discount
                  Did you get anywhere with the air intake temp sensor solution
                  I'm interested if this hasn't gone through yet...
                  cheers
                  Raymond
                  1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                  1987 CQ85RS
                  1994 S2 Avant- Gone
                  1991 V8 -Gone, but lives on in the TDi and CQ
                  Fintray Hillclimb - 33.20s
                  Doune Hillclimb - 55.02s
                  Forrestburn Hillclimb - 52.61
                  • diesel des
                    • 3896
                    The discount was small a max of 5%. The inlet temp can be made work on both systems. I will be ordering 2 in a few weeks. Thanks,des.
                    • raymor
                      • Sep 2003
                      • 597
                      Dez,
                      How exactly does the inlet temp work? and what bits are you going to order ?
                      cheers
                      Raymond
                      1987 CQ85RS
                      1994 S2 Avant- Gone
                      • MarkPS
                        • May 2005
                        • 65
                        Hi
                        Never tried it but looks intersting
                        PLX R500
                        Available on Ebay at
                        PLX ebay
                        Regards
                        Mark
                        88 URQ
                          looks like a knock off of that AVR one in the silver and blue case
                          • dkw_dude
                            • 555
                            • Country: Norway
                            WB lambda sensor location..
                            Hi
                            Is it ok to install the wb lambda sensor in the stock sensor location?
                            Was reading the Zeitronix pages regarding installing http://www.zeitronix.com/installatio...structions.pdf and it recommends placing the sensor at least 16" after the turbo. On my 3" downpipe the sensor is 4" after the turbo.
                            What do tuners do, I hardly believe they weld on a new bung for mapping?
                            Cheers,
                            Leif-Helge
                            Leif-Helge
                            -91 S2 VEMS and Comp Turbo
                            -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                            • aronmatic2
                              • 2129
                              • Country: Hungary
                              i have innovate. its works fine.
                              Real carbon parts for S2 and RS2. Check Carbondesign on facebook
