Hi Guys
I'm having some problems with my '91 3b (Mihnea chipset). I hope someone can help me diagnose what's wrong.
1) Car started pinging at high boost recently in 3/4th gear;
This was the only problem before the service.
2) Sent it for a service and checkup
3) after various tests, I get the car back and they tell me that the head gasket is blown causing the pinging??
4) After the service the car now has a bad missfire as well when cold to the point of cutting out after a cold start
5) On acceleration, the car hesitates especially obvious with small throttle openings
6) Fuel consumption is +/-15% worse than normal
7) When warm, the car feels much smoother, but still not going as it should
Any ideas on what could be wrong with my baby? Could the head gasket be the cause of all the above? I would appreciate any help.
Craig
This was the only problem before the service.2) Sent it for a service and checkup
Craig
