I've had my car plugged into vagcom to try and diagnose it's running problem and the engine speed sensor came up twice.
Now I know this fault will show without the engine running but I had one fault listed for that and another which said something like an intermittant fault with this sensor (sorry can't remember the exact wording). The running problem I would describe as a missfire but the guy with vagcom didn't think it was and said it felt more like an intermittant earth fault as it doesn't happen very often. You can sometimes induce the fault by dropping a gear and flooring it or occasionally with full throttle driving in any gear but it doesn't seem to be limited to those situations. I've replaced the speed sensor which hasn't helped and the problem's really starting to bug me now!
Seems like these cars are never quite right! Please help.
Thanks!!
Seems like these cars are never quite right! Please help.Thanks!!
