Guys i need your help again
I had K26-TO4E on my 93 audi 90 that i installed 3B engine in along with big exhaust, intercooler and so on. It ran well in begining after i finished transplant, but than something happened and it ran like crap maybe one month later. After million checks and million hours of trying to find what is wrong i decided to put my old turbo back on and start from begining. I had feeling that problem may be becuse i dont have proper software and also weather here in US got realy hot. So due to not being able to find anyone to make chip for my set up i put my old turbo back on.
Well now i know what the problem is i just have not found the cause.
Well car basicly goes in limp mode. After car is started and driven off boost goes up to about .7-.8 bar just like it should, than it as soon as it warms up little bit it will ecu will turn of N75 valve and no boost. on top of that i beleive retards timing which makes cur rine like crap also.
I checked codes and there is only one code stored and that is 4343 which is carbon canister frequency valve. that is because i dont have all that emission crap on there any more and i took the valve off. I dont see how this can make it go in limp mode but i am open for any ideas.
Occasionaly when i drive from work i feel like it goes out of limp mode an di start to accelerate, boost come on again but after about 4000 rpm or so it will go back in limp mode.
I checked for boost leaks, i inspected all sensors visualy, i did ecu output test for injectors, boost valve (N75),idle valve and carbon canister valve which i dont have.
Please help i dont know what to do any more
thanks in advance
thanks in advance
