ok here goes again:
my car has some trouble starting in mornings.
changed the hall sender recently...no change - isv cleaned and lubed and working ok.
when its cool in the morning the car will start - when its warm or hot climate..without fail it will mess me around...seems to start after the three attempts, then has trouble settling to idle for about 10 seconds (almost like when the isv is fooked). Seems the amount of attempts required is dependant also on what fuel i have in the motor, i.e. harder to start with optimax but this may be paranoia
after it starts its generally ok for the rest of the day untill i leave it overnight, unless its warm it will mess me around again
wondering if its the fuel pump - had this changed recently but cant say if its installed properly together with the filter - could it be fuel pressure? cos my fuel readings are also all over the shop i.e. reads empty well before the red - then tells me i got 25 miles worth in tank
someone please give me pointers - as this is one of the few things letting this babee down.
thanx
imster
thanx
imster
