Looked through a couple of threads on strokers. Now, seems that the AET and AEL need to be welded to porperly seat the headgasket. Is this absolutly necessary? I maen, can't I use a TDI gasket? Or a custom one? I mean, there are custom gaskets avaliable, isn't there???
Stroker and head gaskets
My engine is a KG. I am using tdi head gasket. You have to drill bigger holes for water.--------------------------------------------------------
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
I just want to say, the tdi gasket water holes smaler than 20vt because the tdi
dose not make that much heat thant 20vt.--------------------------------------------------------
What head and what block you use?--------------------------------------------------------
Yeah, I checked through that. It did not say that I could use a TDi gasket, nor did it say that I couldn't... So I asked again. That is a super stroker thread... Not a super-stroker... a super stroker-thread... Well you know.
Aron - did I get you right - you have a 2.5tdi block and a 20v head and you run a tdi gasket? You just modified the gasket or did you do something to the head or bottom end?Last edited by Henka; 12 August 2005, 18:57.Comment
I am using 20v head and 10v block.
What i did.
1. Welded the big oval hole and make a circle hole on the head.
2. Make the same size water hole on the tdi gasket as the 20v headgasket.
nothing else--------------------------------------------------------
