Hi all, this is my first post and I'm hoping someone may be able to help.
A week ago I nipped out to the shops, and my engine started to run bady - "kangerooing" with the slightest throttle application. I stopped, switched off, and on restarting the problem was gone. It was a hot, sticky day. After reading a lot of the threads here, I suspected I was looking at a MAF or oxygen sensor issue.
Then, 3 days ago, about 5 minutes into a journey, the engine died completely. I coasted to the side of the road, stopped, and on restarting, everything was fine. I pulled away, only 2 minutes later the engine died again. This time the engine wouldnt even crank ! I checked all the fuses, found nothing, so got back in the car and tried again. It started and ran perfectly. Again, it was a hot sticky day.
Then, yesterday afternoon (another hot sticky day) - I went to the car to leave work, and it wouldnt crank. After repeated trying, it suddenly cranked and started, and ran fine for a few minutes, after which it cut out for about a minute. I restarted, and it ran fine.
Can anyone offer any advice ?
Can the ECU over-ride the cranking signal, or can only an aftermarket immobiliser do this ?
When the problem occurs, i.e no cranking, all the other electrics seem OK.
