SQ engine on ebay
SQ engine on ebay
Real carbon parts for S2 and RS2. Check Carbondesign on facebookTags: None -
Fook me that looks like a 7A
...there was a 90q20v rally car i think, wonder if thats where its from. Looks like some sort of mechanical FI unit on the end of the exaust cam, and that intake
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express -
Cast Alloy DHOC 4V cam covers - looks like a 7A85 WR Urquattro, 85 20vT International liveried RallyRep
93 MTMS2 Avant
what kind of fuel injection system?--------------------------------------------------------
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
heres a translation, well nearly
To auction conditions the A engine AUDI 5 Zyl.2,3l.Das complete cream part OF the engines is the more cylinder head, OF thesis is worked on, has large valves, mechanical tappets, Rennockenwellen, adjustable trace wheel and adjustable Nockenwellenrad.Der more cylinder head is at original Sportquattrokopf. Furthermore A 43 mm of OF flat slides is instead OF Drosselklapppen block blocking that complete more cylinder head as waves as the injection pumps comes from Dupree Motorsport.Der engines mount is A production item and must completely worked on want-wants that sales effected more under exclusion OF any guaranteeComment
... Cam cover is from Sport quattro, the DOHC 4V wording was not used on the 7A, although they are interchangeable. The oil filler location of the Sport and 7A are also different.Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eatComment
Mmmm, slide throttle!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
It looks like the injectors that are in the "cage" are getting fired from the cam powered "thingy" on the back of the head.
There must be 5 seperate throttle bodies in there somewhere as well. Is that what the mechanical rods are opening?S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Its A mechanical Injection System with slide throttles
Looks like a Kugelfischer system
Similar to the Lucas system as used on DFV and BDA/BDX Cosworths but much easier to set up and less likely to take the hair off your Face
Dont need a squirty bottle of fuel to start them like you do with a lucas system
The Block on the back of the CAm is the Fuel distribiution block, driven by a keyway in the end of the cam normally
Its more like a diesel injection system than petrol, very high fuel pressure and valves in the metering head rather than injectors near the head.
Throttle slide gives full bore at WOT with no restriction, works like a Guillotine to close off the Inlet tract, terrible running off idle and the fuel puddles on top of the plate, but go like Fook at the top end
We used to run Group 6 Prototypes with BDA`s and BMW M12 motors on Slide throttle mechanical set ups, 2 litres and 320hp Normally aspirated
.... lovely cars would give the Can Am McLarens a run for their money on a twisty track too
Proper motor that........ I can smell the Avgas and Castrol R from here
But it seems to be raped by the hands of rallycrossers. They have nothing saintOriginally posted by CR500DomProper motor that........ I can smell the Avgas and Castrol R from here
when seeking for more HP and Nm
Where is the turbo ?
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
I too was gonna say that the FI unit looks like a Kugelfischer one...
I wonder if that engine has ever ran...
The cam cover is an SQ unit, defo, but the rest of the engine looks 7A-ish to me...
HTH,
Mihnea'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop DirectionsComment
