oil pressure gauge
  • redcar
    • Jan 2005
    • 134
    oil pressure gauge
    my oil pressure gague goes off the clock 5 bar plus . when you turn the key to full ignition. with out the engine run. any guess. the volt gaue is fine the oil temp is fine. it only the oil pressure gague.
    cheers nick
  • Skull
    • 3506
    • Country: Slovenia
    short circuit 100%
    Audi Quattro WR
      Yeah I have the same problem on mine. I changed the sender a while back and it worked fine to start with but has a short or a break in cct now
      • terrybullwon
        • Mar 2006
        • 8782
        cheers nick
        Did you find the problem in the end
        Chef
        • stevieyid
          • Apr 2005
          • 2251
          Anyone know the solution to this? Mine is now doing this so i definately have a short circuit somewhere as per the other thread!
