would this fit in a coupe?
  • WabTheKing
    • May 2004
    • 2567
    anyone know weights/bhp/torque etc<?
    would it fit aby 6speed box?
    6.0 W12 engine
  • S2 Ant
    • 3682
    That engine is huge, i cant imagine there is any way on earth that would fit!
    (prove me wrong! i'd be very impressed!)
    Ant
    2011 Kawasaki Z1000
    • WabTheKing
      • May 2004
      • 2567
      not much bigger than a v8 and that fits, just 2 vr6 engines welded together
      Continuously controlled camshaft phasing for inlet and exhaust valves,
      roller cam followers with hydraulic compensation
      Displacement in cc / bore x stroke in mm / compression ratio
      5998 / 84.0 x 90.2 / 10.75
      Max. power output in kW (bhp) / at rpm
      309 (420) / 6000
      Max. torque in Nm / at rpm
      550 / 3500-4750
      • Mihnea
        • 1288
        Done one a few weeks ago, it dynoed 445 PS at 6500 and 590Nm on good fuel...
        They do sound sweet!!!!
        You need to rewire a lot to get it to work in a coupe but I can't see why it wouldn't work....
        Cheers,
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • Ski
          • 2591
          there is a passat w8 isnt there? maybe that would fit better?
          ABY Coupe
            Nice project if you ever robbed a bank to get hold on the engine!
            • S2 Ant
              • 3682
              How easy to come by are the S4 engines? 2.7 V6 Bi-turbo?
              Ant
              2011 Kawasaki Z1000
              • dan_b
                • Sep 2003
                • 3670
                What about the V10 engine they've put in the Toerag, that's just two straight 5s bolted together and we know a straight 5 fits
                  LOL you've been thinking what ive been thinking mate.
                  • ottawa coupe
                    • 852
                    is it an iron block? if it is i'd guess that even if you got it to fit, the difference in weight would certainly be enough to affect handling.
                    that said, a 12 cyl coupe would be amazing
                    1993 UrS4...aka the rocket powered living room
                    • S2 Ant
                      • 3682
                      Ive been thinking it a long time now which is why ive not pulled mine off the road yet. That ABT kitted red coupe sits as my wallpaper teasing me everyday LOL, ive never come across any tho to be able to even consider it.
                      Ant
                      2011 Kawasaki Z1000
                      • WabTheKing
                        • May 2004
                        • 2567
                        Cheers,
                        Mihnea
                        any idea's how easy it would be to get around imobilzer/traction control etc which will no doubt be built into the ecu
                        • WabTheKing
                          • May 2004
                          • 2567
                          aluminium block, dry sump!
                          anyone know how much a VR6 engine weighs, and how much a 3B engine weighs?
                          • martinjs
                            • 3205
                            But not if you put it where the back seat is?? LOL
                            My ultimate coupe would be twin engined, 2x 500hp in line 5's
                            • dan_b
                              • Sep 2003
                              • 3670
                              Why not just go for a v10 then?!
