I have a 19913b with the engine out and I have found a problem I think with the rotor arm it moves 2 to 3 mm side to side rocks up and down on the shaft and the shaft also moves in and out about 3mm the car when running never ran well disspite trying almost every thing the local main dealer said its the rong distributor ,mine is part no 034905205Q they say I should replace it whith part no 034905237bx the paper work whith this car dos,nt say anything about it ever being replaced but what about the rotor arm mine has part no 052905225c dont no if its been changed or not any ideas guy s
rotor arm
AFAIK its the same dist setup as a 7A, i had a similar problem caused by wear of the original plastic gear which tend to fail completly after a while. The fix is to source one of the metal gears (can be found on ebay) and fit it along with a few thin washers to take up all the slack, you should get about 1mm play left/right and even less up/down then. With the wear your open to all sorts off issues with ignition scatter etc...
Mark.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express -
