Having replaced my TPC due to leak, & replaced the afterrun thermo switch on water
manifold, my main fan nor TPC want to work
This has not work since buying the beast
Could anyone recomend my next line of attack.
Have you touched the two thermo switch connectors together to see if there is power there? If so it could just be that the car has not been hot enough for it to come on.
Hello rs2paul
start by checking you have a complete eletrical circuit, this can be done by firstly
taking the 2 wires from the afterrun thermo switch on water manifold and touch them together,you hear 1st stage fan and should be able to feel afterrun pump working,
if this fails check fuses,relays and resistor
