Custom remap needed!
  • |Maku|
    • Apr 2005
    • 248
    • Home: Estonia
    Hy!
    Could any of you suggest me a company or a person who can make me custom chips for Audi S4. I have RS2 turbo, custom cams, polished exhaust manifold, welded intake manifold and cats removed. I have sent 2 emails to MRC already but theres no response. Who else to turn to?
    Tnx, Marko!
  • Doug_RS2
    • 3847
    Marko sorry I will get back to you ASAP. The problem is your location, as I understand you are not in the UK...
    Thanks,
    Mihnea from Doug's computer
    • porkkis
      • 1994
      Where are you located?
      • |Maku|
        • Apr 2005
        • 248
        • Home: Estonia
        I live in Estonia. I holp to get soft by email, i can write soft to chips, thats not a problem to me.
        • porkkis
          • 1994
          Errm. Custom remap over email. That's new to me
          • |Maku|
            • Apr 2005
            • 248
            • Home: Estonia
            So lets do something new Why is it so hard? Im sendind all values and list of things Im using..
            • Doug_RS2
              • 3847
              I have done this already in the past, the problem is the time the process can take, especially as I'm constantly bouncing back and forth between the UK, Belgium and France, and sometimes I don't have access to my emails....
              Mihnea
              • charlie
                • 447
                Mihnea
                Minhea, I still waiting for my re-mapp. I've been waiting anxiously for months
                and getting abit frastrated
                ( Hope it doesn't sound rude. )
                RS2 MTM
                • Doug_RS2
                  • 3847
                  Charlie, Doug has PM'ed you last time I was over (2 weeks ago?) and he had no answer from you at all...
                  I'll PM you tomorrow...
                  Mihnea
                  • |Maku|
                    • Apr 2005
                    • 248
                    • Home: Estonia
                    Mihnea, dont forget about my "tiny" problem.. Im sure that you have some software already that is best for rs2 turbo and exhaust manifolt + no cats. If i have aftermarket cams, does it matter too when youre programming software?
                    • bcdesigns
                      • Apr 2004
                      • 193
                      • Country: Portugal
                      xxx
                      Audi 100 TDI :mischeif:
                      MRC remap; Green Injectors; Champion Sparks; Forge DV 006; Samco Intake pipes; K&N filter
                      Xenon 6500k; Pillar Boost gauge; Alpine CDA 9835R on Bose with Infinity Sub
                      Oettinger 8x18" with GS-D3 225/40ZR18; Bilstein with H&R Springs (-40mm)
                      www.autopamplona.com
                      www.mrctuning.com
                      • bcdesigns
                        • Apr 2004
                        • 193
                        • Country: Portugal
                        Mine arrived by mail from mihnea! just had to plug the chips
                        www.mrctuning.com
                        • Tommy200rs
                          • 285
                          Originally posted by |Maku|
                          Hy!
                          Tnx, Marko!
                          hi,
                          you can contact Mika for remap in Finland close to Estonia:
                          http://www.turbotec.com/yritys/yhteys.htm.
                          Hope this helps. What injectors are you using ? / fuel pressure regulator ? 3bar MAP inside ECU ?
                          "Email custom chips" won´t be 100% perfect, because observations are difficult to do properly and it will take to much time to complete with targetted quality.
                          rgs,
                          Tommy
                          • |Maku|
                            • Apr 2005
                            • 248
                            • Home: Estonia
                            Originally posted by Tommy200rs
                            hi,
                            rgs,
                            Tommy
                            Thx Tommy!
                            Currently Im usind stock AAN injectors but Im thinking about 3B injectors. Also Im using stock fuel pressure regulator and i dont see need for 3 bar map sensor. Im not going to use over 2 bar pressure anyway. Im thinking about 1,6 bar for everyday use and my goal is about 340-350hp.
                            Of course email custom chips wont be 100% perfect but i want to make the best of it. Im not gonna drive all the way to UK
                            • Sweeper
                              • 1317
                              • Country: Latvia
                              |Maku| : Belgium aren't that far away. There are ship from Latvia going to Keln(Germany) , then there is about 400km till Belgium. I'm going to travel there for a remap once i pass my Technical Inspection. =]
                              Vadim.
                              New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
