Possible Air flow meter prob?
  • GasMan
    • Apr 2005
    • 5
    I Have had this Audi s2 coupe 92 5speed manual for six months,
    first major problem replace steering rack, Sorted.
    Now i have an intermittant fault when accelerating i have removed the intercooler and resealed o ring, replaced turbo hose split all other hoses seem tight sounds poor when idle and stalls at lights cleened idle valve but suspect air flow meter?
    it seems alright from cold but if you stop then start the fault comes back, gradually putting your foot down will allow full rev range but foot to the boards it will stutter occasional back fire .
    any help very gratefull
    cheers G
  • elijahallens2
    • Aug 2004
    • 310
    Could be MAF, or POS, or bad coil, or boot. If you know someone near with the same engine its easy to swap things out to rule them out before spending big money replacing things that may not be bad.
    Elijah
    91 Audi Coupe Quattro- AAN engine transplant
    • nick92S2
      • 56
      Had the same symptoms on mine a couple of months ago - it turned out to be the MAF!!
      • GasMan
        • Apr 2005
        • 5
        Just Getting Maf sent down from newcastle nothing to lose i guess! an il have a spare one if its ok.
        cheers
        • BRY
          • 3755
          Where are you?
          • mastermind
            • Jan 2005
            • 244
            • Country: South Africa
            I had to replace a coil when my RS2 did that.
            The Red Baron
            (R)S2 spec, 034 GT3071
            Wagner Short Intake and Intercooler
            Whiteline, Custom Shocks with external reservoirs
            8pot calipers with A8 discs
            Vems
            • GasMan
              • Apr 2005
              • 5
              I live near High Peak Buxton derbyshire.
              Fitted part off an Rs2 in my luch hour today and seems to have done the trick!! fingers crossed
              i may axtually get a month out of six of care free driving!
              Four new tyres,brand new Mintex pads,steerin sorted and now its runnin right gonna be a good weekend.
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                Weekend? It's still only Wednesday!!!
                __MDC__
                Martin Cutting
                • WabTheKing
                  • May 2004
                  • 2567
                  is that jamie?
                  • GasMan
                    • Apr 2005
                    • 5
                    i know it was only wednesday but im on call! so cant stray to far from home.
                    • GasMan
                      • Apr 2005
                      • 5
                      And yes it is, William.
