FPR on 3B
  • Jeffer
    • 2057
    FPR on 3B
    Is there also a feulpressure regulator for the 3B injection strip? The one I saw from bosch was only for the ABY and ADU.
    cheers
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    The FPR on the 3B isn't on the end of the fuel rail like the ABY. It is mounted beneath the inlet manifold - just follow the fuel lines and you'll find it.
    Paul
    • Jeffer
      • 2057
      Sorry Paul,
      My post is a bit confusing :wacked:
      I wanted to ask if there is a 5 bar FPR for the 3B.
      I've seen the other ones that click in the rail, but those are for ABY an ADU.
      greets
      High Octane website
        The FPR from the NM/7A engine is rated for approx 4.2bar and is a straight replacement for the 3B item.
        Maybe Mihnea knows the trick for modifying the 3B FPR to achieve higher pressures. ALternately, I bet there are motorsport suppliers of an adjustable regulator that could be used - perhaps with new hose unions etc.
