3b vacuum hose routing
  • PeterS
    • 423
    Question for the S2 3Bers....
    My 3B engine has what I believe to be a vacuum port in the rear, which is different than the "typical" 200 3b engine which has no port.
    Could someone let me know which vacuum line connects to the valve cover port (of course its in the rear, under the ISV ;-(
    thanks in advance!
    -peter
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
  • martinjs
    • 3205
    It goes into the hose which fits onto the large breather outlet on the side of the block.
    HTH
    • SteveH
      • 4460
      Yeah, the nipple on the back of the head connects to the long hose that 'T's off the main PCV hose. This is not a vacuum hose but part of the crankcase ventilation system. If there's nothing connected to it, you'll probably have a load of oil down the back of the block.
      91 Modded 3B
      14 A6 Avant Black Edition
