Fuel Pump - Urgent!!!
  • BlackBullet
    • 146
    • Country: Brazil
    Hello freaks!
    I´m im Holidays with my S2, and the engine has stoped!
    I saw the all electrical, because I thought that any sensor was the problem!
    But I have power on the Motor.
    So, my problem I hope is the Fuel Pump...
    Where is this pump?
    Can anyone send a picture from this Pump????
    I´m 350km far from my home... and I hope that I can go back home soon!
    Thanks for any help!
    Bye!!!
    And... Luck for me!!!
    Rafael Pinto
    Audi S2 1994/1995 Avant - Black
    Audi RS2 1994/1995 - Black
  • elijahallens2
    • Aug 2004
    • 310
    The pump is in the tank. If you pop the hatch and pull the carpet back there is an access hole you can get to it through. Its a bit of a pain to get it out but if you find the clips that hold it in and pull them apart it will slide out.
    Elijah
    91 Audi Coupe Quattro- AAN engine transplant
    • BlackBullet
      • 146
      • Country: Brazil
      Yeah!
      I founded!!!
      But there, there are 4 cable!
      Than, any one can help me with this cable?
      My idea is to take direct from the batery on the right switch and see if the Pump will start or not!
      Any one have any other idea to test????
      Here is beach, the sun shines... but I really need my car!!!
      I'm very thankfull for any help!!!
      Perhaps I can solve this problems!!!
      Reguards,
      Rafael Pinto
      • ~Delta
        • Apr 2005
        • 797
        Be careful if you apply battery power to the pump if the tank is open. A single spark could destroy your S2 if ignites the fuel vapour.
        Never show a fool a half built house.
        Never underestimate the power of stupid people in large groups.
        Life is like a **** sandwich
        The more bread you have, the less **** you eat
          Originally posted by BlackBullet
          Yeah!
          I founded!!!
          Reguards,
          You dont need to do that, you can test the fuel pump from the fuel pump relay. Also it could be the relay thats gone.
          Do a search theres a diagram showing you how to test the pump from the relay on the forum.
            BTW the four wires, the two thin ones are for the fuel gauge. the two thick ones for the pump. if you have a multimet you could try turning ignition on and putting an ammeter on the pump supply to see if it is drawing current?
            • BlackBullet
              • 146
              • Country: Brazil
              Hey guys!!!!
              So...
              The problem is the fuel pump...
              There is 12V there when we try to turn on the engine.. but no noise appears!
              I want now to take the pump out!
              There is a 4" plastic thread!!! any one know how to take it out?
              Thanks for all helps!
              Reguards,
              Rafael Pinto
                use a piece of angle iron or similar to fit into the slots then twist and the retaining clip will come off. Open up and undo banjo on pump and wires then lift basket out and unclip the pump
                this should help http://www.s2forum.com/forum/showthr...=bosch+fitting
                • BlackBullet
                  • 146
                  • Country: Brazil
                  Yeah!!! I did it!!!
                  The Fuel pump is on my hands!!! And the problem is on it!!!
                  12V direct on it.. and.. nothing... really nothing!!!
                  I need a new pump!!!
                  There is another pump better for my S2 Avant??? or better just a new as my poor one???
                  I will put my S2 on a Truck today... than came back home 350km... take my old Golf III and go back again to the beach!!!! Because.... the Party need to go one!!! heheh
                  Thanks for helps!!!
                  Rafael Pinto
