MC engine
  • donce
    • Aug 2005
    • 127
    • Country: Lithuania
    MC engine
    i know this is little off topic,cos its not with s2,but its with coupe and turbo so i wanted to ask,what is the cheapest way to get MC engine to 270-300 crankHP? do i need to change the ECU? and does the gearbox from 7a fit to MC? thanks
  • porkkis
    • 1994
    You need to ditch the mechanic injection and replace it with megasquirt or vems or something more expensive. And.. the 42mm compressor on MC1 nor 43 on MC2 isn't capable of producing that power on a 10v engine, so bigger turbo is also needed. Better exhaust manifold is a good idea.
    Use 7A or S2 3B flywheel and clutch to fit the engine.
    WG area will be tight with original EM.
    • caterpillar
      • 2480
      the flywheel are 34mm thickness,a plane one,singelmass
