Possible replacement for ABY, ADU and AAN power packs
  • 90quattrocoupe
    • Nov 2003
    • 771
    This guy has done a replacement of the ABY, ADU and AAN components with ones of a 1.8T. I don't know much about this stuff, but it looks to be cheaper and more compact. He hasn't finished is write ups yet.
    Greg W.
    The 1.8t coil pack conversion shopping list
    User account number (aid): 15624
    Posted by UrS4boy on 2005-09-20 22:52:09
    I've been developing this conversion in my head for a number of years because I always thought that, eventually, our OEM coils would no longer be made and I wanted a back-up plan for my car. In the last four or five months, I noticed that I was getting some missing/bucking under WOT, and high boost, at high speed. I figured coil (or POS) but I didn't want to spend the money on replacing old (but perhaps robust) technology when newer technology is out there.
    I know all about the 1.8t coil pack recall on some of the Bremi-made coil packs but I think that VW/Audi is through all that now. For whatever reason (excess supply, the need to do some good PR), these coil packs are now very reasonably priced. Since I had the need and the price was right (about $200 - $250 for the parts versus the OEM equivalent of about $925 for five coils and two OEM POS units), I decided to make the conversion. As you may have seen from my posts, it seems to be working absolutely fine - so far. (YMMV). Just like new OEM parts should. Hey, they are OEM - just from a newer technology!!
    If you are interested in making this conversion, you need the parts listed below. They are mostly dealer parts. I got mine through Kris at VM Autohaus (604-298-9637) who said he would be interested in putting "kits" together with all the parts (except items 7 and 8 that you need to scrounge). For Canadians, using Kris wouldn't be a bad idea. For those in the States, there is still a bit of a gap between the US dollar and Canadian dollars that should still make it an okay deal. However, I know ECS tuning has the coil packs for about the equivalent price (in absolute dollars)that I bought mine for.
    Anyway, here is the shopping list:
    1. 5 units of 06B 905 115L late model 1.8t coil packs (which are POS, coil and plug connectors all in one) should be about $25 each. Note the "L" is very important. DO NOT ACCEPT ANYTHING ELSE - unless they are known to be better.
    2. 5 units of 4B0 973 724 empty four wire connectors (to mate to the 115Ls) (about $10 each) (Seems expensive but they are worth it)
    3. 10 pieces of 000 979 133 A - two female spade connector pig-tails (NOTE: If I
    had this to do over again, I would search out the equivalent empty pins and crimp/solder continous pieces of wire rather than spicing these into the system.) (About $4 each piece). These pins go into the rear of the 4B0 973 724 four pin connectors.
    4. 25 pieces of 357 972 741 A - wire sealing grommets (red) for the 4B0 973 724
    connectors and 000 979 133 A wires (about $0.30 each). They seal the wires into the 4B0 973 724 connectors. Install BEFORE you connect the wires to anything else.
    5. 5 pieces 6X0 971 921 A - two-part plastic boots for the 4B0 973 724 connectors. (about $3 each). At first I thought they were cheesy but they are actually quite slick. They are designed to retain 1/4" corrugated split wire loom which helps to corral those wires.
    6. 3 pieces of 000 979 134 - two male spade connector pig-tails (again, I would search out a source of empty male pins and forget slicing these in)
    7. Two, four-pin male spade connectors to fit into the four pin female spade connectors that carry the signal from the ECU (and a ground) and normally fit into the four pin end of the POS units (N122 and N127). You can search for somehting better but I found that there is a four pin, left tail light, connector PN 191 972 704 from a the mid-90's Jetta IIIs (might also be in some Audis because the plug has both VW and OOOO molded into it). These connectors are female "pin" power plugs but they have the exactly correct pin spacing for the the OEM POS input connectors. They need to be modified (a lot). But this is pretty easy.
    I bought two of these taillight plugs with the four wires and connectors (each). By
    removing the female pins (from the connector side with two bent paper clips to push the retaining pins in), you can salvage eight pins for use in the other connector projects (if you want to save a few $). Once the female pins are out,
    you need to trim off 4 mm on the nose of the connector and then remove
    all the protruding bits. I used an X-acto saw (that I have had for 40
    years when I used to make models as a kid). Don't trim much more than 4
    mm or when you load the male pins, 000 979 134 (come 2 to wire, you need
    5 so three wires), they will push right through (don't ask how I know
    this). I think it works out that if you cut right through the center of each O in the OOOO symbol, the amount removed is just right. You load the 000 979 134 pins from the back.
    Once the pins are in, you can see how the newly re-gendered
    connector fits into the POS connector. Spacing is correct but there is
    a lot of exposed, non-waterprood, non-connected, plastic to deal with. I am planning on zap strap(s) and some silicone to solve this problem.
    8. 2, three pin (male) power connectors to receive switched power going to the
    primary side of the coils. These connectors are on the connector rack on the fire wall and are the two beside the 02 connector. You need to replace them because when you remove the OEM coil pack, you disconnect and remove these connectors. I cruised a wrecking yard and found that the solution is the end of a dead three wire VW O2 sensor (e.g. 90 to 92 Jetta II). You need two. The male pin connector even has the grove to slip into the firewall bracket and fits the power connector perfectly. I crimped on purple power wires that will be connected to Pin No. 1 on each of the five coil pack connectors.
    9. Labling tape (1/2" masking tape) so you can keep all the wires organized as to where they are going or coming from.
    10. Colour-coded wire, butt connectors and good crimpers, and/or soldering iron, solder and heat shrink tubing, 1/4", 3/8" and 1/2" plastic wire loom, zap straps, etc.
    11. Instructions and/or the S4 and 1.8t wiring diagrams (I will post the instructions
    shortly)
    The adventure begins. I expect that you will post improvements/alternatives to my solutions for items 7 and 8.
    Dave F.
  • 90quattrocoupe
    • Nov 2003
    • 771
    Link to write up.
    http://forums.audiworld.com/s4s6/msgs/83216.phtml
    • Bibby
      • Aug 2004
      • 1043
      Interesting post, cheers for telling us about it.
      acidtrax
        Theres another post on the forum about this, there's Audiman's mate running a golf with the same coilpacks.
        Only issue is you can't use the original rocker cover.
        • porkkis
          • 1994
          Great!
          How are the coils kept securely at their position? Was that mentioned? I probably missed that..
          • 90quattrocoupe
            • Nov 2003
            • 771
            Originally posted by porkkis
            Great!
            It was mentioned in a earlier post about clipping onto the spark plug. If that is the right word. He may also be modifing the cover to work.
            He hasn't finished with that part yet I believe. You may want to scan past posts on Audiworld for more info. He is supposed to do a picture write up and everything. He says the car seems to run fine with the install, but has not done a WOT or long road test yet.
            More to come I guess.
            Greg W.
            • Stick Insect
              • Dec 2003
              • 2338
              Time for a custonm valve cover then!
              You know you want one....
              David
              • kwlw
                • Sep 2004
                • 1025
                • Country: Lithuania
                David
                It will be more true "if you drive in winter - you need one" . Because I think snow/rain and salt will make dust from these coilpacks ...
                Sau
                • Markus
                  • 184
                  Dave on the audifans.com s-car-list regarding the "clipping onto spark plug":
                  Markus
                  '94 Kristallsilber-metallic S2 Avant.
                  • repo
                    • Dec 2004
                    • 893
                    Just remember to blow with an airgun into the plug pits before removing the plugs, or all the dirt and small stones will go into the cylinders.
                    That in case You don't fit the cover on, or the custom isn't sealed like the stock one is...
                    • Sweeper
                      • 1317
                      • Country: Latvia
                      Fond this topic by mistake , so did anyone tryed id ?
                      Vadim.
                      New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
                      • kalsket
                        • Sep 2004
                        • 78
                        Hint: vag-original wiring harness for coilpacks 1J0971658L (part# is right even though ETKA doesn't know it) should cost less than 40$ (for 4cylinder engine) wich is quite a lot less than you'll have to pay for all parts when bought separately. It seems that same connector is used in VW VR5 coils (engine code AQN), could somebody try to find out if similar wiring harness is available for this engine?
                        4F 2006 avant 3.0tdi quattro
                        4B 2002 S6 avant quattro
                        typ85 sedan quattro with "minor" changes
                        • porkkis
                          • 1994
                          Now we have some results. My friend replaced his coils with these and the car is running fine. Rubber seal part from the coil had to be cut out to fit them but no other mods required except that and the wiring job.
                          The coils are quite securely held on the plugs by themselves.
                          • Erikb
                            • Jul 2004
                            • 648
                            Hey all,
                            I saw on audiworld, that they made an excellent write up of the 1.8t coilpack conversion with photo's, wire diagram and shoppinglist.
                            http://forums.audiworld.com/s4s6/msgs/85357.phtml
                            Maybe this can be usefull for someone.
                            Erik
                            Getting everything sorted out for my 5++ hp project
                            • Audi500HP
                              • Apr 2004
                              • 85
                              • Country: Chile
                              Amaizing work, this is why I am addicted to this forum!
                              Thanks for the Links to Dave and Erik.
                              Audi S2 94 6 speed ABY-ADU 330hp, Lancia delta EVO2 mint
                              Dr.Ferdinand
