Hi i have recently noticed that when i lift off the power i get slight jolts. What do u think this could be? I was thinking engine mounts or gearbox mounts what do u think? Is there a way of checking the mounts to see if they are ok?
gearbox and rear diff mounts are the usual suspects,rear diff will usually give a thumping noise when you come on/off the power,it may be a worn engine mount,best way is to get underneath and get a lever in between the mounts to check for play..
