Hi, what temp should Jimmy run at.
Last night it stayed at a quarter of the way. When im stuck in traffic the fan kicks in no problem, tho.
Does this mean that the thermostat is faulty
it depends on the type of thermostat used.Since in england the whether is mildly cold-to cold,audis are made to be driven in 90 degrees,or around tha figure.The thermostat has it's own temperature threshold.It could be working on 70 85 90 100 degrees etc..
if it where broken,then it wouldnt work at all,and you would have no ventilator movement,and temperature going way up in no time!
that is excactly what happens to mine.2 notches above in traffic,a little less than 90 in normal driving,even more less than 90 in normal speeding(below 3500rpm)
